<%@ Page Title="" Language="C#" MasterPageFile="~/Site.Master" AutoEventWireup="true" CodeBehind="tst.aspx.cs" Inherits="ASSET.Maintain.tst" %>
<%@ Register Assembly="Infragistics4.Web.v13.1, Version=13.1.20131.1012, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.Web.UI.GridControls" TagPrefix="ig" %><asp:Content ID="Content1" ContentPlaceHolderID="HeadContent" runat="server"></asp:Content><asp:Content ID="Content2" ContentPlaceHolderID="MainContent" runat="server"> <asp:ScriptManager ID="ScriptManager1" runat="server"> </asp:ScriptManager> <ig:WebDataGrid ID="WebDataGrid1" runat="server" Height="350px" Width="400px" AutoGenerateColumns="False" DataKeyFields="ControlsId" ondatafiltered="WebDataGrid1_DataFiltered" ondatafiltering="WebDataGrid1_DataFiltering" onrowselectionchanged="WebDataGrid1_RowSelectionChanged"> <Columns> <ig:BoundDataField DataFieldName="CONTROLSID" Key="ControlsId" DataType="System.Int32"> <Header Text="Control ID" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="SHORTDESCRIPTION" Key="SHORTDESCRIPTION" DataType="System.String"> <Header Text="Short Description" /> </ig:BoundDataField> </Columns> <Behaviors> <ig:Selection CellClickAction="Row" EnableCrossPageSelection="True" RowSelectType="Multiple" CellSelectType="Multiple"> </ig:Selection> <ig:RowSelectors> </ig:RowSelectors> <ig:VirtualScrolling> </ig:VirtualScrolling> <ig:Filtering> <ColumnSettings> <ig:ColumnFilteringSetting ColumnKey="CONTROLSID" /> </ColumnSettings> </ig:Filtering> </Behaviors> </ig:WebDataGrid></asp:Content>
using System;using System.Collections.Generic;using System.Linq;using System.Web;using System.Web.UI;using System.Web.UI.WebControls;using BLL;using DTO;using Infragistics.Web.UI.GridControls;
namespace ASSET.Maintain{ public partial class tst : System.Web.UI.Page { protected void Page_Load(object sender, EventArgs e) {
ControlsBLL oControlsBLL = new ControlsBLL(); ControlsDTO oControlsDTO = new ControlsDTO();
WebDataGrid1.DataSource = oControlsBLL.Select(oControlsDTO); WebDataGrid1.DataBind();
protected void WebDataGrid1_RowSelectionChanged(object sender, Infragistics.Web.UI.GridControls.SelectedRowEventArgs e) { //IList<int> ids = new List<int>(); //int id = 0; //int index = 0;
//foreach (GridRecord row in e.CurrentSelectedRows) //{ // if (row == null) // { // IDPair pair = e.CurrentSelectedRows.GetIDPair(index); // id = Convert.ToInt32(pair.Key[0]);
// } // else // { // id = Convert.ToInt32(row.DataKey[0]); // }
// if (!ids.Contains(id)) // { // ids.Add(id); // } // index++; //}
//Session["SELECTED_CONTROLS"] = ids; }
protected void WebDataGrid1_DataFiltered(object sender, FilteredEventArgs e) { if (Session["SELECTED_CONTROLS"] != null) { List<int> lstControlsIDs = new List<int>(); lstControlsIDs = (List<int>)Session["SELECTED_CONTROLS"];
SelectedRowCollection selectedRow = this.WebDataGrid1.Behaviors.Selection.SelectedRows;
foreach (int id in lstControlsIDs) {
foreach (GridRecord gr in WebDataGrid1.Rows) { if (gr.Items[0].Row.Items[0].Value.ToString() == id.ToString()) { selectedRow.Add(gr); //selectedRow.Add(WebDataGrid1.Behaviors.Selection.SelectedRows.GetIDPair(index)); } } }
protected void WebDataGrid1_DataFiltering(object sender, FilteringEventArgs e) { IList<int> ids = new List<int>(); int id = 0; int index = 0; foreach (GridRecord row in WebDataGrid1.Behaviors.Selection.SelectedRows) { if (row == null) { IDPair pair = WebDataGrid1.Behaviors.Selection.SelectedRows.GetIDPair(index); id = Convert.ToInt32(pair.Key[0]);
} else { id = Convert.ToInt32(row.DataKey[0]); }
if (!ids.Contains(id)) { ids.Add(id); } index++; }
For example I select rows number 10 and 20, and then I want to filter the grid. The results of this filtering contain the row 20, so I want to have that row shown as selected, the same when I clean the filter and want to have everthing listed again, I want those two rows appear as selected I've got a SESSION variable which I'm filling with the selected rows in the WebDataGrid1_DataFiltering function, so when it applies the filter and goes to the WebDataGrid1_DataFiltered I will loop through the grid and select the ones that in the SESSION variable.
My code reaches the "selectedRod.Add(gr)" line, but nothing seems to happen when the page is displayed. I've really run out of ideas...I've been with this for 4 days :S Please help me!!! Thanks Diego
Hello Diego,
Did you check the following sample (the bottom one) which demonstrates the same functionality - http://www.infragistics.com/products/aspnet/sample/data-grid/persistent-selection ?
It appears to work correctly by setting selected rows in row selection changed event.
Let me know if this sample works correctly on your side too.
Hi, thanks for your reply.
I don't think that's totally my case, because I'm using filters in this grid, and that's when I loose the selection in the grid. That's why I'm capturing all the selected ids in a SESSION variable. The issue I'm having is that when the "filtered" function is executed, when I try to loop on the results and mark them as selected (when they match their id with the ones I've got captured in the SESSION variable), they're not being marked as selected when the page is displayed.
I'm uploading 2 screenshots so you get a better idea of what I'm trying to explain in case that it's not so clear.
Thanks!
this is the screenshot that shows you what happens when the filter is applied and what is shown to the user...and marked with red, the row that should appear as selected because it did execute the selectedRow.Add(gr); line.
We will have to check this functionality additionally with the filtering applied. I will update you through the created case with any additional information available.
Thank you.
