We are using WebHierarchicalDataGrid (Version -13.1.20131.2069)
When i am deleting the 2 rows continuously i am not received any issues when i am deleting the next row continuously (3rd) i have received the following issue.
Here i have mentioned code snippets.
<script type="text/javascript" id="igClientScript1"> // Redirect to location page. function whdgVendor_ContainerGrid_DoubleClick(sender, eventArgs) { if (sender._level != 0) { return false; } else { var row = eventArgs.get_item().get_row().get_dataKey()[0]; __doPostBack('btnRedirect', row); } } // Confirmation dialog for deleting the branch. function ConfirmDeletion(sender, eventArgs) { // Open a dialog to use asking for a yes/no about deletion var continueDelete = confirm("Are you sure you want to delete this record?"); // if end-user says no, cancel the delete action if (!continueDelete) eventArgs.set_cancel(true); } </script>
<ig:WebHierarchicalDataGrid ID="whdgVendor" runat="server" Width="100%" EnableAjax="False" EnableAjaxViewState="False" EnableDataViewState="True" InitialDataBindDepth="1" AutoGenerateColumns="False" DataKeyFields="VendorID" DataMember="Vendor" AutoGenerateBands="False" OnRowsDeleting ="gridVendorList_RowsDeleting" onpageindexchanged="grdVendorList_PageIndexChanged" oncolumnsorted="grdVendorList_ColumnSorted" ondatafiltering="grdVendorList_DataFiltering" oninitializerow="whdgVendor_InitializeRow" Key="VendorID" EnableViewState="True"> <Bands> <ig:Band AutoGenerateColumns="False" DataKeyFields="VendorContactID" Key="VendorContactID" DataMember="VendorContacts" Width="100%" Height="100%" onpageindexchanged="grdVendorList_PageIndexChanged" oncolumnsorted="grdVendorList_ColumnSorted" ondatafiltering="grdVendorList_DataFiltering"> <Columns> <ig:BoundDataField DataFieldName="ContactName" Key="ContactName"> <Header Text="Contact name"></Header> </ig:BoundDataField> <ig:BoundDataField DataFieldName="DepartmentID" Hidden="True" Key="DepartmentID"> <Header Text="DepartmentID"></Header> </ig:BoundDataField> <ig:BoundDataField DataFieldName="DepartmentName" Key="DepartmentName"> <Header Text="Department"></Header> </ig:BoundDataField> <ig:BoundDataField DataFieldName="ContactNumber" Key="ContactNumber"> <Header Text="Contact no"></Header> </ig:BoundDataField> <ig:BoundDataField DataFieldName="EmailID" Key="EmailID"> <Header Text="Email"></Header> </ig:BoundDataField> <ig:BoundDataField DataFieldName="ARContactName" Key="ARContactName"> <Header Text="ARContact name"></Header> </ig:BoundDataField> <ig:BoundDataField DataFieldName="ARContactNumber" Key="ARContactNumber"> <Header Text="ARContact number"></Header> </ig:BoundDataField> <ig:BoundDataField DataFieldName="VendorContactID" Hidden="True" Key="VendorContactID"> <Header Text="VendorContactID"></Header> </ig:BoundDataField> <ig:BoundDataField DataFieldName="VendorID" Hidden="True" Key="VendorID"> <Header Text="VendorID"></Header> </ig:BoundDataField> </Columns> <Behaviors> <ig:Sorting> </ig:Sorting> <ig:Paging> </ig:Paging> <ig:Filtering> </ig:Filtering> </Behaviors> </ig:Band> </Bands> <ClientEvents DoubleClick="whdgVendor_ContainerGrid_DoubleClick" /> <Columns> <ig:BoundDataField DataFieldName="VendorID" Hidden="True" Key="VendorID"> <Header Text="VendorID"></Header> </ig:BoundDataField> <ig:BoundDataField DataFieldName="VendorName" Key="VendorName"> <Header Text="Name"></Header> </ig:BoundDataField> <ig:BoundDataField DataFieldName="Address" Key="Address"> <Header Text="Address"></Header> </ig:BoundDataField> <ig:BoundDataField DataFieldName="City" Key="City"> <Header Text="City"></Header> </ig:BoundDataField> <ig:BoundDataField DataFieldName="State" Key="State"> <Header Text="State"></Header> </ig:BoundDataField> <ig:BoundDataField DataFieldName="PhoneNumber" Key="PhoneNumber"> <Header Text="Contact no"></Header> </ig:BoundDataField> <ig:BoundDataField DataFieldName="AlternatePhoneNo" Key="AlternatePhoneNo"> <Header Text="Alternate no"></Header> </ig:BoundDataField> <ig:BoundDataField DataFieldName="Fax" Key="Fax"> <Header Text="Fax"></Header> </ig:BoundDataField> <ig:BoundDataField DataFieldName="Notes" Key="Notes"> <Header Text="Notes"></Header> </ig:BoundDataField> </Columns> <Behaviors> <ig:Activation> </ig:Activation> <ig:EditingCore AutoCRUD="False"> <EditingClientEvents RowsDeleting="ConfirmDeletion"/> <Behaviors> <ig:RowDeleting /> </Behaviors> </ig:EditingCore> <ig:Selection CellClickAction="Row" RowSelectType="Single"> </ig:Selection> <ig:RowSelectors> </ig:RowSelectors> <ig:Sorting> </ig:Sorting> <ig:Paging> </ig:Paging> <ig:Filtering> </ig:Filtering> </Behaviors> <EmptyRowsTemplate> <div style="text-align: center;"> No records found </div> </EmptyRowsTemplate> </ig:WebHierarchicalDataGrid>
how to handle this issue .please kindly reply me.
Thanks & Regards,
P.Narayanan.
Set EnableViewState="false" on each control inside each template field; e.g.
<ig:WebHierarchicalDataGrid runat="server" ID="hdg" DataSourceID="hds" DataKeyFields="ID" OnInitializeRow="hdg_InitializeRow"> <Columns> <ig:TemplateDataField Key="ID" Text="Relationship ID"> <ItemTemplate> <asp:Label runat="server" ID="lblID" EnableViewState="false" /> </ItemTemplate> </ig:TemplateDataField> <ig:TemplateDataField Key="Add"> <ItemTemplate> <asp:Button runat="server" ID="btn" Text="Add" CommandName="Add" EnableViewState="false" /> </ItemTemplate> </ig:TemplateDataField>
</Columns>
<Bands>...</Bands>
<Behaviors>...</Behaviors>
If you still need assistance with the matter, please let me know.
Hello Narayanan Pandaram,
Your markup seems to be correct and I am unable to tell what is causing this exception from the provided details. I would need a small isolated sample reproducing the issue so I can investigate it further. Thank you.
