In my WebDataGrid I'm dynamically hiding rows by setting their Css class depending on certain values. Row adding is enabled on this Grid and I've discovered that if the first row is hidden, the plus symbol in the Add row section disappears. Any other row can be hidden without it affecting the Add Row. I have narrowed it down to the display: none; part of the Css that is the reason it is being hidden. Is this expected and if so, is there a way to work around it? I have attached the project.
Thank you for your help,
Brandon
