Hi all!
I try to use the webslider in a WebTab with the settings AsyncMode=On and EnableLoadOnDemand=True. When I initially load the page and the tab with the slider is visible, it is working fine. Now I switch through the tabs. When I switch to the tab with the Slider again the slider doesn't work anymore. I can't drag the thumb anymore!!! When I try it the cursor switches to the "no drag allowed cursor" (the circle with the stroke through it).
Why is this happening? What am I doing wrong?
Thx in advance
Bob
I Just found out that there is the same problem with a WARP
This may be due to the Slider being built on top of the Akido framework which is built on ASP.NET AJAX. The ASP.NET AJAX implementation differs from the WARP implementation and may lead to incompatibilities. Since the tab's built in AJAX uses the WARP implementation, I would recommend that you use an update panel inside of each tab or outside the entire tab control and turn off the built in Ajax of the tab.
I just found this help article which explains my statement above:
http://help.infragistics.com/Help/NetAdvantage/NET/2008.2/CLR2.0/html/Web_WARP_and_WebTab.html
I excluded the Tab containing the slider from LoadOnDemand. That works for me. Thx alot for your help!
Hello
I have the same problem. But in my GUI I should have WARP with the WebSlider on it, because of sliders value is changing with the trigger from other control.
What to do with this? Could you give advice?
Maybe, there is already newer version of the WebSlider?
Thank you!
