I am attempting to recreate an application that I did without Infragistics, this time I'm using Infragistics. What I am trying to do, is show a Column chart which has the number of boards processed and the time on the X Axis. Now, this time is obtained from the SQL Stored Procedure. Right now, the chart and data-grid display great, however, the X Axis shows the "BoardProcessed" and not the time. Please see attached screen shot. The first one is what it should look like, the second, is what I am getting now.
My Current Code:
SqlConnection connection = new SqlConnection(FactoryServerMesdbConnection.ConnectToDatabase); SqlCommand cmd = new SqlCommand("dbo.HourlyProductionYield", connection) { CommandType = CommandType.StoredProcedure, CommandText = "dbo.HourlyProductionYield", Connection = connection }; //Adding values to StoredProcedure parameters. cmd.Parameters.AddWithValue("@StartDate", startDate); cmd.Parameters.AddWithValue("@Shift", shift); cmd.Parameters.AddWithValue("@Line", productionLine); cmd.Parameters.AddWithValue("@OperationTaskID", operationTaskId); connection.Open(); SqlDataReader drDataReader = cmd.ExecuteReader(); webDg.DataSource = drDataReader; webDg.DataBind(); } //Fill datatable with data. public void DisplayData() { var currentDate = DateTime.Today.ToShortDateString(); GetData(currentDate, 1, 1, 100, wdgL1SMT); ChartData(currentDate,1,1,100, ucL1SMT); } public void ChartData(string startDate, int shift, int productionLine, int operationTaskId, UltraChart ucChart) { SqlConnection cdConnection = new SqlConnection(FactoryServerMesdbConnection.ConnectToDatabase); SqlCommand cmd = new SqlCommand("dbo.HourlyProductionYield", cdConnection) { CommandType = CommandType.StoredProcedure, CommandText = "dbo.HourlyProductionYield", Connection = cdConnection }; //Adding values to StoredProcedure parameters. cmd.Parameters.AddWithValue("@StartDate", startDate); cmd.Parameters.AddWithValue("@Shift", shift); cmd.Parameters.AddWithValue("@Line", productionLine); cmd.Parameters.AddWithValue("@OperationTaskID", operationTaskId); cdConnection.Open(); using (SqlDataAdapter da = new SqlDataAdapter()) { DataTable dt = new DataTable(); da.SelectCommand = cmd; da.Fill(dt); ucL1SMT.DataSource = dt; ucL1SMT.DataBind(); ucL1SMT.Data.IncludeColumn(dt.Columns["Shift"],false); ucL1SMT.Data.IncludeColumn(dt.Columns["Line"], false); ucL1SMT.Data.IncludeColumn(dt.Columns["OperationID"], false); ucL1SMT.Data.IncludeColumn(dt.Columns["Hour"], true); } } } }
Hi Trent,
As this is a duplicate case of ‘CAS-178673-H2R4W1’ and can see Mike B is assisting you to that case,
I would recommend you to close this case and continue with the other one.
Please do provide the information to mikeB to get continue support from him.
