Hi Team,
We are using 2015.2 version Infragistics webdatagrid control and applied Excelstylefilter.
When we checked at server side in DataFiltering event, the eventArg.ColumnFilters value getting as null
protected void WebDataGrid1_DataFiltering (object sender, FilteredEventArgs eventArg) {
foreach (ColumnFilter column in eventArg.ColumnFilters )
and also we have checked at client side in DataFiltering function, her also we are unable to retrieve filtered column information.
code snippet like as below:
## Client side function information has been set up at server side
this.WebDataGrid1.Behaviors.Filtering.FilteringClientEvents.DataFiltering = "DataFiltering";
## Client side function:
function DataFiltering(sender, e) {
var columnFilters = e.get_columnFilters();
Please provide possible solution.
I have created and attached a small sample trying to reproduce the issue. On the server-side data filtering event, the column filters are retrieved as expected:
protected void wdg_DataFiltering(object sender, Infragistics.Web.UI.GridControls.FilteringEventArgs e) { foreach (ColumnFilter item in e.ColumnFilters) { } }
Please test it on your side and let me know how it behaves.
About the client-side data filtering event, I have created the following case for you: 'CAS-207078-Y3D4Z4' and will update you through it. You could see it in your account in the 'Support Activity' page.
6457.Sample.zip
