Since we can't use postback and viewstate when using MVC framework, what WebDataGrid behaviors are enabled (or work) when used with MVC? The behaviors used in Issue Tracker application are the only ones enabled?I played around with Issue Tracker application and updated the webdatagrid settings to use Column Moving and Sorting but I am getting javascript error... I assume Row Editing would have to be implemented on the client side to avoid any postbacks, etc. Thanks in advance.
Yulmee:
Right now the column moving behavior initiates a post back when you drop the column on the grid. I am have asked engineering to make this an option. I will see when that change is scheduled and get back to you.
All the editing behaviors are reliant on the postback model so, yes you would have to implement editing on the client to account for this.
Best,
Craig
Does sorting functionality needs Postback/Viewstate enable?
Can we use sorting functionality of Webdatagrid in MVC?
Unfortunately not - sorting will initiate a post back as well.
