I am getting the following error:
‘Could not load type 'System.Web.UI.ScriptReferenceBase' from assembly 'System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'.
I have used WebSlider control Infragistics version used was "8.3.20083.2138", I am getting this error.
Nagendran<-->
Hi Nagendran,It has been a while since your post, in case you are still in need of assistance I would be glad to help.Based on the message that you are getting, your issue is a general ASP.NET matter and as such, may be unrelated to Infragistics controls. I suggest you try the solutions and workarounds related to this specific error. Some suggestions on how to tackle this matter with respect to our controls are available from:https://www.infragistics.com/community/forums/f/ultimate-ui-for-asp-net/44933/server-error-could-not-load-type-system-web-ui-scriptreferencebase-from-assemblyAdditionally, you may want to consider the resolutions suggested here:https://forums.asp.net/t/1273185.aspxPlease contact me if you have further questions.Petar IvanovDeveloper Support EngineerInfragistics, Inc.https://www.infragistics.com/support
