Hello
I would like to set change the ContenURL of a tab item using javascript. I checked out the Documentation and it references getting an instance of LayoutPane. However I can't figure out what methods to call to return an instance of this object?
http://help.infragistics.com/Help/NetAdvantage/ASPNET/2010.1/CLR3.5/html/WebTab~Infragistics.Web.UI.LayoutPane_members.html
I have attached my html for reference
<div id="WebTabContainer"> <ig:WebTab ID="WebTab1" runat="server" ScrollButtons-AutoHide="true" Width="99%" Height="700px"> <Tabs> <ig:ContentTabItem runat="server" Text="Empty" > </ig:ContentTabItem> <ig:ContentTabItem runat="server" Text="Branches" ScrollBars="Hidden" ContentUrl="Branches.aspx"> </ig:ContentTabItem> <ig:ContentTabItem runat="server" Text="Members" ScrollBars="Hidden" ContentUrl="Members.aspx"> </ig:ContentTabItem> <ig:ContentTabItem runat="server" Text="RRCodes" ScrollBars="Hidden" ContentUrl="RRCodes.aspx"> </ig:ContentTabItem> <ig:ContentTabItem runat="server" Text="Clients" ScrollBars="Hidden" ContentUrl="Clients.aspx"> </ig:ContentTabItem> <ig:ContentTabItem runat="server" Text="Accounts" ScrollBars="Hidden" ContentUrl="Accounts.aspx"> </ig:ContentTabItem> <ig:ContentTabItem runat="server" Text="Orders" ScrollBars="Hidden" ContentUrl="Orders.aspx"> </ig:ContentTabItem> </Tabs> <ClientEvents UrlLoaded="UltraWebTab1_AfterSelectedTabChange" /> <PostBackOptions EnableLoadOnDemandUrl="True" EnableLoadOnDemand="true" EnableAjax="true" /> <AjaxIndicator Enabled="True" Location="MiddleCenter" /> </ig:WebTab>
Figured It out:
var tab = $find("<%= WebTab1.ClientID %>");
var gta = tab.getTabAt(1);gta.set_contentUrl('yourpage.aspx');
I'm still frustrated by the documentation as It staes:
var resultVar = instanceOfLayoutPane.get_contentUrl();
How does instanceoflayoutpane resolve to getTabAt? In the example cant you simply state use the getTabAt() method to return an instance of Layoutpane?
Maybe I am missing something? Any explanation would help.
Thank-you.
Hi, When ActiveTabChange client side event fires, the second argument TabItemCancelEventArgs will be holding selected TabItem index that could be used as a argument for getTabAt method. Once you reference the selected tab you can use get_contentUrl(),set_contentUrl()methods to manupalate the Url string like: function Change(sender, e) { var tab = sender.getTabAt(e.get_tabIndex()); alert(tab.get_contentUrl()); } I hope this, helps. Please let me know if you need further assistance on this case. Sincerely, Batnasan Developer Support Engineer, MCAD Infragistics www.infragistics.com/support
Sincerely,
Batnasan
Hi
I am also using same WEBTAB in MVC project , on chnage of tab i want to load or call that particluar view.
