Hi all,
I want to display dropdownlist in cells of WebDataGrid. Is this possible?
I don't want to define columns at design time as my grid columns are dynamic.
I know this is possible with UltraWebGrid, but with WebDataGrid I need help to do the same.
Can anyone there help me out!
Hello chetanpawar,
You can use the dropdown editor control with the "WebDataGrid" like shown here - https://www.infragistics.com/samples/aspnet/data-grid/dropdown-editors
Or you can use Template Column and insert Microsofts dropdown control in it like shown in the following link - https://help.infragistics.com/Help/Doc/ASPNET/2010.3/CLR4.0/html/WebDataGrid_Using_Item_Template.html?_ga=2.201863253.575049412.1567621743-123582674.1567621743&_ga=2.201863253.575049412.1567621743-123582674.1567621743
Neither of these links work. The one on top gives a 404. The second one displays a configuration error.
We are trying to add a DropDownList to a WebDataGrid that contains a list of actions. The intent is to display a list of rows and in each row, include a drop down list of all of the actions that can be performed against that row. There are two basic sets of actions based upon the status of each row. There are multiple status codes. You can think of the DDL not having any relationship to any of the data in the WebDataGrid.
The webdategrid is populated from a DataTable in the code behind. We are using Version=11.2.20112.2086.
