I'm trying to get a webdropdown to load (without postback) from the value of a textbox. Is this possible? The user enters a number in the textbox and that number is used in a stored procedure to return a set for a dropdown. Right now I do this server-side with auto post backs.
I'm starting by adding the onchange event to the textbox:
textbox.Attributes.Add("onchange", "return textboxChanged(this);");
that calls this js function:
function textboxChanged(textControl) { //Gets reference to the the webdropdown var webdropdown= $find('<%= webdropdown.ClientID %>'); //clear current selection webdropdown.set_currentValue("", true); webdropdown.loadItems(textControl.value); }
but i don't think this is right. it doesn't pass the right objects to the webdropdown_ItemsRequested event. Can this approach work or do i need to go a different direction?
Thanks for any help you can provide.
Do you mean that in the ItemsRequested server-side handler you have, the Value property doesn't contain the "textControl.value" you are setting?
Could it be that textConrtrol.value doesn't refer to the correct text to filter by?
Angel
