Hi folks,
I am wondering how to show expand/collapse when there are no child rows. The reason is, I want to show an empty child row if there are no child rows. Any suggestions are welcome.
I am databinding my hierarchical grid manually to a generic list (eg: a list of categories, each of which can contain a list of products). Also, I am not sure how to add a new row (to the bottom of the grid) in the parent when the user clicks a button on the page.
Thanks for any help!
Marshal
Hey Marshal,
We should be able to come up with some solutions for your problems. If you have a child band defined and the row adding behavior is on in it, the child grid should always appear even if there are no rows of data. Although there is a bug right now if you do that with load on demand. Another option is for you to manual load on demand. If you set the IsEmptyParent property of a row, it will have an expansion indicator. Then you can handle row islands populating. Cancel the event and then add a ContainerGrid that you make to the row's RowIslands collection.
As for your second question, if you use the row adding behavior, it will add the row to your datasource for you if you use AutoCRUD. If you don't want the add row, just turn on editing core and do the following.
var grid = $find("WHDG1");
grid.get_gridView().get_rows().add(newVals); where newVals is an array of values for the new row. You could do that on your button click. Let us know if you need more help.
regards,David Young
Hi David,
adding new child row when no child rows are present
Thanks for the reply. Please see the attached screenshot. I have set the isemptyparent property to true and have the rowadding behavior for the child band. I am not doing a load on demand (adding rowislands). I can see the header but not an empty row. I tried clicking around to see if it shows a textbox (from the editorprovider) like the other child rows but no luck.
Can you attach the markup of your grid?
thanks,Dave
Sure David, here you are:
<igtblh:WebHierarchicalDataGrid ID="gvUtilityDetail" runat="server" AutoGenerateColumns="False" DataKeyFields="ID" Height="350px" Width="100%" Font-Size="10pt" Key="ID" AutoGenerateBands="False" StyleSetName="Default" OnRowUpdating="gvUtilityDetail_RowUpdating" OnRowAdding="gvUtilityDetail_RowAdding" OnRowIslandsPopulating="gvUtilityDetail_RowIslandsPopulating" > <ExpandCollapseAnimation SlideOpenDirection="Auto" SlideOpenDuration="10" SlideCloseDirection="Auto" SlideCloseDuration="10" /> <ExpandButton ImageUrl="~/Images/Grid/ighg_Expand.gif" AltText="+" HoverImageUrl="~/Images/Grid/ighg_Expand.gif" PressedImageUrl="~/Images/Grid/ighg_Expand.gif"></ExpandButton> <CollapseButton ImageUrl="~/Images/Grid/ighg_Collapse.gif" AltText="-" HoverImageUrl="~/Images/Grid/ighg_Collapse.gif" PressedImageUrl="~/Images/Grid/ighg_Collapse.gif"></CollapseButton> <Columns> <igtblh:BoundDataField DataFieldName="ID" Key="ID" Hidden="true"> </igtblh:BoundDataField> <igtblh:BoundDataField DataFieldName="AccountNumber" Key="AccountNumber"> <Header Text="Account #" /> </igtblh:BoundDataField> <igtblh:BoundDataField DataFieldName="MeterName" Key="GuidMeter"> <Header Text="Meter" /> </igtblh:BoundDataField> <igtblh:BoundDataField DataFieldName="FuelName" Key="GuidFuel"> <Header Text="Fuel" /> </igtblh:BoundDataField> <igtblh:BoundDataField DataFieldName="SupplierName" Key="GuidSupplier"> <Header Text="Supplier" /> </igtblh:BoundDataField> <igtblh:BoundDataField DataFieldName="FuelUnitName" Key="GuidFuelUnit"> <Header Text="Fuel Unit" /> </igtblh:BoundDataField> <igtblh:BoundDataField DataFieldName="Interval" Key="Interval"> <Header Text="Interval" /> </igtblh:BoundDataField> <igtblh:BoundDataField DataFieldName="RateCode" Key="RateCode"> <Header Text="Rate Code" /> </igtblh:BoundDataField> <igtblh:BoundDataField DataFieldName="ChargeType" Key="ChargeType"> <Header Text="Charge Type" /> </igtblh:BoundDataField> <igtblh:BoundDataField DataFieldName="PreviousReadingDate" Key="PreviousReadingDate" DataFormatString="{0:d}" DataType="System.DateTime"> <Header Text="Previous Reading" /> </igtblh:BoundDataField> <igtblh:BoundDataField DataFieldName="ReadingDate" Key="ReadingDate" DataFormatString="{0:d}" DataType="System.DateTime"> <Header Text="Current Reading" /> </igtblh:BoundDataField> <igtblh:BoundDataField DataFieldName="UnitConsumption" Key="UnitConsumption" DataType="System.Double"> <Header Text="Unit Consumption" /> </igtblh:BoundDataField> <igtblh:BoundDataField DataFieldName="InvoiceCost" Key="InvoiceCost" DataFormatString="{0:c}" DataType="System.Decimal"> <Header Text="Invoice Cost" /> </igtblh:BoundDataField> </Columns> <Bands> <igtblh:Band Key="GuidUtilityRateDetail" AutoGenerateColumns="false" OnRowUpdating="gvUtilityDetailChild_RowUpdating" DataKeyFields="GuidUtilityRateDetail" DefaultColumnWidth="150px" DataMember="UtilityRateDetailList" Width="60%"> <ExpandButton ImageUrl="~/Images/Grid/ighg_Expand.gif" AltText="+" PressedImageUrl="~/Images/Grid/ighg_Expand.gif" > </ExpandButton> <CollapseButton ImageUrl="~/Images/Grid/ighg_Collapse.gif" AltText="-" PressedImageUrl="~/Images/Grid/ighg_Collapse.gif"> </CollapseButton> <Columns > <igtblh:BoundDataField Key="GuidUtilityRateDetail" Hidden="true" > <Header Text="ID" /> </igtblh:BoundDataField> <igtblh:BoundDataField DataFieldName="Name" Key="Name"> <Header Text="Rate Name" /> </igtblh:BoundDataField> <igtblh:BoundDataField DataFieldName="UnitCost" Key="UnitCost" DataFormatString="{0:c}" DataType="System.Decimal"> <Header Text="Unit Cost" /> </igtblh:BoundDataField> <igtblh:BoundDataField DataFieldName="LSCost" Key="LSCost" DataFormatString="{0:c}" DataType="System.Decimal"> <Header Text="L.S. Cost" /> </igtblh:BoundDataField> </Columns> <Behaviors> <igtblh:EditingCore EnableInheritance="true" AutoCRUD="False"> <Behaviors> <igtblh:RowAdding EnableInheritance="true"> <ColumnSettings> <igtblh:RowAddingColumnSetting ColumnKey="Name" EditorID="prRateName" /> <igtblh:RowAddingColumnSetting ColumnKey="UnitCost" EditorID="prUnitCost" /> <igtblh:RowAddingColumnSetting ColumnKey="LSCost" EditorID="prUnitCost" ReadOnly="True" /> </ColumnSettings> </igtblh:RowAdding> <igtblh:CellEditing EnableInheritance="True"> <ColumnSettings> <igtblh:EditingColumnSetting ColumnKey="Name" EditorID="prRateName" /> <igtblh:EditingColumnSetting ColumnKey="UnitCost" EditorID="prUnitCost" /> <igtblh:EditingColumnSetting ColumnKey="LSCost" EditorID="prUnitCost" ReadOnly="True" /> </ColumnSettings> </igtblh:CellEditing> <igtblh:RowDeleting EnableInheritance="True" /> </Behaviors> </igtblh:EditingCore> <igtblh:Sorting> </igtblh:Sorting> </Behaviors> </igtblh:Band> </Bands> <Behaviors> <igtblh:EditingCore> <Behaviors> <igtblh:CellEditing EnableInheritance="True" CellEditingClientEvents-ExitedEditMode="WebDataGridView_ExitedEditMode"> <ColumnSettings> <igtblh:EditingColumnSetting ColumnKey="GuidFuelUnit" EditorID="prFuelUnit" /> <igtblh:EditingColumnSetting ColumnKey="GuidSupplier" EditorID="prSupplier" /> <igtblh:EditingColumnSetting ColumnKey="GuidMeter" EditorID="prMeter" /> <igtblh:EditingColumnSetting ColumnKey="GuidFuel" EditorID="prFuel" /> <igtblh:EditingColumnSetting ColumnKey="PreviousReadingDate" EditorID="prPreviousReading" /> <igtblh:EditingColumnSetting ColumnKey="ReadingDate" EditorID="prCurrentReading" /> </ColumnSettings> <EditModeActions MouseClick="Single" /> </igtblh:CellEditing> <igtblh:RowAdding EnableInheritance="True"> <ColumnSettings> <igtblh:RowAddingColumnSetting ColumnKey="GuidMeter" EditorID="prMeter" /> <igtblh:RowAddingColumnSetting ColumnKey="GuidFuel" EditorID="prFuel" /> <igtblh:RowAddingColumnSetting ColumnKey="GuidSupplier" EditorID="prSupplier" /> <igtblh:RowAddingColumnSetting ColumnKey="GuidFuelUnit" EditorID="prFuelUnit" /> <igtblh:RowAddingColumnSetting ColumnKey="PreviousReadingDate" EditorID="prPreviousReading" /> <igtblh:RowAddingColumnSetting ColumnKey="ReadingDate" EditorID="prCurrentReading" /> </ColumnSettings> <EditModeActions EnableOnActive="True" /> </igtblh:RowAdding> </Behaviors> </igtblh:EditingCore> <igtblh:Selection CellClickAction="Row" RowSelectType="Single"> </igtblh:Selection> <igtblh:Activation Enabled="true"> </igtblh:Activation> </Behaviors> <EditorProviders> <igtblh:DropDownProvider ID="prMeter" StretchHeight="True"> <EditorControl DropDownContainerMaxHeight="200px" EnableAnimations="False" EnableDropDownAsChild="False" TextField="MeterAbv" ValueField="ID" ID="ddlMeter" Width="75px"> <DropDownItemBinding TextField="MeterAbv" ValueField="ID" /> </EditorControl> </igtblh:DropDownProvider> <igtblh:DropDownProvider ID="prFuel" StretchHeight="True"> <EditorControl DropDownContainerMaxHeight="200px" EnableAnimations="False" ID="ddlSysFuel" ValueField="ID" TextField="ValFuel" EnableDropDownAsChild="False" Width="75px"> <DropDownItemBinding TextField="ValFuel" ValueField="ID"></DropDownItemBinding> </EditorControl> </igtblh:DropDownProvider> <igtblh:DropDownProvider ID="prSupplier" StretchHeight="True"> <EditorControl DropDownContainerMaxHeight="200px" Width="75px" EnableAnimations="False" ID="ddlEnergySupplier" TextField="SupplierAbv" ValueField="ID" EnableDropDownAsChild="False"> <DropDownItemBinding TextField="SupplierAbv" ValueField="ID"></DropDownItemBinding> </EditorControl> </igtblh:DropDownProvider> <igtblh:DropDownProvider ID="prFuelUnit" StretchHeight="True" EditorControl-DisplayMode="DropDownList"> <EditorControl DropDownContainerMaxHeight="200px" EnableAnimations="False" Width="75px" ID="ddlSysFuelUnit" TextField="AbvFuelUnit" ValueField="ID" EnableDropDownAsChild="False"> <DropDownItemBinding TextField="AbvFuelUnit" ValueField="ID"></DropDownItemBinding> </EditorControl> </igtblh:DropDownProvider> <igtblh:DatePickerProvider ID="prPreviousReading"> <EditorControl ID="dpPrevious" DisplayModeFormat="d"> </EditorControl> </igtblh:DatePickerProvider> <igtblh:DatePickerProvider ID="prCurrentReading"> </igtblh:DatePickerProvider> <igtblh:TextEditorProvider ID="prRateName"> <EditorControl ID="txtRateName" MaxLength="50" Width="150px"> </EditorControl> </igtblh:TextEditorProvider> <igtblh:CurrencyEditorProvider ID="prUnitCost"> <EditorControl ID="txtUnitCost" DataMode="Decimal" MaxDecimalPlaces="2" MinDecimalPlaces="2" Width="150px"> </EditorControl> </igtblh:CurrencyEditorProvider> </EditorProviders></igtblh:WebHierarchicalDataGrid> Here's what I do on code behind: gvUtilityDetail.DataSource = UtilityDetailList; gvUtilityDetail.DataBind(); foreach (ContainerGridRecord row in gvUtilityDetail.Rows) row.IsEmptyParent = true;
