2070
Moving Control References to Web.config
How does one 'Move Control References to Web.config' as per the documentation in the 2010.3 release? The documentation (both local and online) show an not found error for this page.
This would be extremely useful for me to have all the control references in one place rather than in each ASPX form. So if possible please give the details on how to do this.
Also, once this is done will the project still load and run in the VS 2008 IDE environment? Or is this 'run-time' only?
/Tom
Parents
  • 2070
    Verified Answer
    Never mind, I figured it out. Following is example in WEB.CONFIG for IG 2010.3:
        <pages>
          <controls>
            <add tagPrefix="asp" namespace="System.Web.UI" assembly="System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" />
            <add tagPrefix="asp" namespace="System.Web.UI.WebControls" assembly="System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" />
            <add tagPrefix="ig" namespace="Infragistics.Web.UI.GridControls" assembly="Infragistics35.Web.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" />
            <add tagPrefix="ig" namespace="Infragistics.Web.UI.LayoutControls" assembly="Infragistics35.Web.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" />
            <add tagPrefix="ig" namespace="Infragistics.Web.UI.EditorControls" assembly="Infragistics35.Web.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" />
            <add tagPrefix="ig" namespace="Infragistics.Web.UI.ListControls" assembly="Infragistics35.Web.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" />
            <add tagPrefix="ig" namespace="Infragistics.Web.UI.NavigationControls" assembly="Infragistics35.Web.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" />
            <add tagPrefix="ig" namespace="Infragistics.Web.UI" assembly="Infragistics35.Web.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" />
            <add tagPrefix="igtxt" namespace="Infragistics.WebUI.WebDataInput" assembly="Infragistics35.WebUI.WebDataInput.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" />
            <add tagPrefix="ighedit" namespace="Infragistics.WebUI.WebHtmlEditor" assembly="Infragistics35.WebUI.WebHtmlEditor.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" />
            <add tagPrefix="igmisc" namespace="Infragistics.WebUI.Misc" assembly="Infragistics35.WebUI.Misc.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" />
          </controls>
        </pages>
Reply Children
No Data
