1590
Tab Menu in Asp.Net
Hi
I have to develop Tab Menu in Asp.net and I want to fire client Side Onclick event. So could you please suggest me which control can I go for?
Mostly the tab menu design will be same as Infragistics community Header, but it's One level right now.
I will appreciate If you provide any sample Tab menu.
Anil Kumar
Parents
  • 7499
    Hello Anil,
    I recommend you to use our WebTab control that accomidates your needs.
    To know more about WebTab, please refer to the following links.
    Getting started with WebTab
    http://help.infragistics.com/NetAdvantage/ASPNET/2011.1/CLR4.0/?page=WebTab_Getting_Started_with_WebTab.html
    Using WebTab
    http://help.infragistics.com/NetAdvantage/ASPNET/2011.1/CLR4.0/?page=WebTab_Using_WebTab.html
    Samples browser
    http://samples.infragistics.com/aspnet/ComponentOverview.aspx?cn=tab
    Please let me know if I can provide any further assistance regarding this matter
  • 1590
    posted in reply to [Infragistics] Surya
    You are response came bit late because I have already developed the Tab Menu using WebTab control. You are response helped me create better Tab Menu.
    But I have stuck in between few design issues which I need your help.
    1) I am not able to apply a theme to my Tab menu. Please provide me a sample applying a Theme.
    2) Critical problem is I have set the WebTab Width to "100%". But it crossing my web browser width. I have attached the code and screenshot below.
    Code id below:-
    <table width="100%" style="height: 100%;" border="1">
            <tr>
                <th class="header" style="height: 46px;" align="left" valign="top">
                    <img alt="Credit Suisse Logo" src="Images/Logo.PNG" id="global_logo" style="visibility: visible;
                        vertical-align: top; text-align: left; table-layout: fixed; background-color: transparent;"
                        height="100%" />
                    <font size="4px" color="white" style="font-family: Arial, Helvetica, sans-serif;
                        font-weight: bold; position: relative; top: 15px; right: -5px; text-align: center">
                        Mix Analytics</font>
                </th>
            </tr>
            <tr>
                <td style="height: 94%; text-align: left; vertical-align: top;">
                    <ig:WebTab ID="WebTab1" runat="server" DisplayMode="Scrollable" Height="100%" BackColor="#A8C6DB"
                         Font-Bold="True" Font-Size="Smaller" ForeColor="#3366FF"
                        SelectedIndex="0" Width="100%"> <%--1889px--%>
                        <Tabs>
                            <ig:ContentTabItem runat="server" Text="Dashboard" TabSize="150px" MarginLeading="1"
                                AutoSize="True" >
                                <Template>
                                    <iframe id="Iframe1" src="http://www.google.com/"
                                        style="height: 100%; width: 100%; text-align: left; vertical-align: top; border: 0;" >
                                    </iframe>
                                </Template>
                            </ig:ContentTabItem>
                            <ig:ContentTabItem runat="server" Text="Reporting" MarginLeading="1" AutoSize="True"
                                TabSize="150px">
                                <Template>
                                    <iframe id="frameUrl" src="http://forums.infragistics.com/silverlight/default.aspx"
                                        style="height: 100%; width: 100%; text-align: left; vertical-align: top; border: 0;">
                                    </iframe>
                                </Template>
                        </Tabs>
                        <%-- Enable Tab moving feature.--%>
                        <TabMoving Enabled="false" />
                        <%--Enable close buttons for the tabs.--%>
                        <%--  <CloseButton Enabled="True" />--%>
                        <ContentPane AutoSize="True">
                        </ContentPane>
                    </ig:WebTab>
                </td>
            </tr>
        </table>
Reply Children
