i try to add custom day in webMonthCalender control on client side, when user select multiple dates they will add in custom day array, and holiday css will be applied to custom days,
i have write this code but nothing will happen ,
function addCustom() { var calendar = $find('<%=WebMonthCalendar1.ClientID%>'); var days = calendar.get_selectedDates(); for (var i = 0; i < days.length; i++) { if (days[i] != null && days[i] != "") { calendar.addCustomDay(days[i].getFullYear(), days[i].getMonth(), days[i].getDate(), days[i].getDay(), false, "H", 'holiday');
this fuction is fire on click event of button,
the "holiday"css is include on page which is given below
.holiday{ background-color:Blue !important;}
day is adding in custom day but css is not applying ;
i verify it by alert(customday[0].css); it showing "holiday".
why it is not applying .
kindly help me what im doing wrong , thanks
Hi Arsalan,
I apologize for delay, because that question missed my attention.
I think that in your codes you use wrong methods of Date object. The getDay() returns day of the week, but not day of the month, and getMonth() returns values in range of 0-11, but not in range of 1-12.
I wrote for you example to add/remove custom day for the selected date in calendar. To test, you may copy/paste those codes in any aspx.
<style type="text/css"> .red { color: Red; } </style><script type="text/javascript"> function addDay() { var cal = $find('WebMonthCalendar1'); var date = cal.get_selectedDate(); if (!date) return; var year = date.getFullYear(), month = date.getMonth() + 1, day = date.getDate(); var days = cal.get_customDays(); var i = days ? days.length : 0; while(i-- > 0) { // check if day already exists if(days[i].day == day && days[i].month == month && days[i].year == year) return; } cal.addCustomDay(year, month, day, -1, null, null, 'red'); cal.repaint(); } function removeDay() { var cal = $find('WebMonthCalendar1'); var date = cal.get_selectedDate(); if (!date) return; var year = date.getFullYear(), month = date.getMonth() + 1, day = date.getDate(); var days = cal.get_customDays(); var len = days ? days.length : 0, i = len; while(i-- > 0) { // find day if(days[i].day == day && days[i].month == month && days[i].year == year) break; } if(i < 0) return; if(i < len - 1) days[i] = days[len - 1]; days.length--; cal.repaint(); }</script>
<ig:WebMonthCalendar ID="WebMonthCalendar1" runat="server"></ig:WebMonthCalendar><input type="button" value="AddCustom" onclick="addDay()" /><input type="button" value="RemoveCustom" onclick="removeDay()" />
