I was attempting to go through the tutorial on the WebDialogWindow and I have run into an error after I drag the control to my form:Indirect reference is being made to assembly System.Web.Extensions version 3.5.0.0, which contains 'Infragistics.Web.UI.LayoutControls.WebDialogWindow'. This Project references a prior version of System.Web.Extensions version 1.0.61025.0. To use 'Infragistics.Web.UI.LayoutControls.WebDialogWindow', you must replace the reference to System.Web.Extensions with version 3.5.0.0 or higher.
I have changed my Web.config to reference 3.5.0.0, but I am still getting this error.Here is my current Web.config:<?xml version="1.0"?><configuration> <configSections> <sectionGroup name="system.web.extensions" type="System.Web.Configuration.SystemWebExtensionsSectionGroup, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"> <sectionGroup name="scripting" type="System.Web.Configuration.ScriptingSectionGroup, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"> <section name="scriptResourceHandler" type="System.Web.Configuration.ScriptingScriptResourceHandlerSection, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" requirePermission="false" allowDefinition="MachineToApplication"/> <sectionGroup name="webServices" type="System.Web.Configuration.ScriptingWebServicesSectionGroup, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"> <section name="jsonSerialization" type="System.Web.Configuration.ScriptingJsonSerializationSection, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" requirePermission="false" allowDefinition="Everywhere"/> <section name="profileService" type="System.Web.Configuration.ScriptingProfileServiceSection, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" requirePermission="false" allowDefinition="MachineToApplication"/> <section name="authenticationService" type="System.Web.Configuration.ScriptingAuthenticationServiceSection, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" requirePermission="false" allowDefinition="MachineToApplication"/> </sectionGroup> </sectionGroup> </sectionGroup> <section name="infragistics.web" type="System.Configuration.SingleTagSectionHandler,System, Version=1.0.3300.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/> </configSections> <infragistics.web styleSetName="Default" styleSetPath="~/ig_res"/> <system.web> <pages> <controls> <add tagPrefix="asp" namespace="System.Web.UI" assembly="System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/> </controls> </pages> <!-- Set compilation debug="true" to insert debugging symbols into the compiled page. Because this affects performance, set this value to true only during development. --> <compilation debug="true"> <assemblies> <add assembly="System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/> <add assembly="Infragistics35.Web.v8.1, Version=8.1.20081.2033, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/> <add assembly="System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/> <add assembly="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089"/> <add assembly="System.Design, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/> </assemblies> </compilation> <httpHandlers> <remove verb="*" path="*.asmx"/> <add verb="*" path="*.asmx" validate="false" type="System.Web.Script.Services.ScriptHandlerFactory, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/> <add verb="*" path="*_AppService.axd" validate="false" type="System.Web.Script.Services.ScriptHandlerFactory, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/> <add verb="GET,HEAD" path="ScriptResource.axd" type="System.Web.Handlers.ScriptResourceHandler, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" validate="false"/> </httpHandlers> <httpModules> <add name="ScriptModule" type="System.Web.Handlers.ScriptModule, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/> </httpModules> </system.web> <system.web.extensions> <scripting> <webServices> <!-- Uncomment this line to customize maxJsonLength and add a custom converter --> <!-- <jsonSerialization maxJsonLength="500"> <converters> <add name="ConvertMe" type="Acme.SubAcme.ConvertMeTypeConverter"/> </converters> </jsonSerialization> --> <!-- Uncomment this line to enable the authentication service. Include requireSSL="true" if appropriate. --> <!-- <authenticationService enabled="true" requireSSL = "true|false"/> --> <!-- Uncomment these lines to enable the profile service. To allow profile properties to be retrieved and modified in ASP.NET AJAX applications, you need to add each property name to the readAccessProperties and writeAccessProperties attributes. --> <!-- <profileService enabled="true" readAccessProperties="propertyname1,propertyname2" writeAccessProperties="propertyname1,propertyname2" /> --> </webServices> <!-- <scriptResourceHandler enableCompression="true" enableCaching="true" /> --> </scripting> </system.web.extensions> <system.webServer> <validation validateIntegratedModeConfiguration="false"/> <modules> <add name="ScriptModule" preCondition="integratedMode" type="System.Web.Handlers.ScriptModule, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/> </modules> <handlers> <remove name="WebServiceHandlerFactory-Integrated"/> <add name="ScriptHandlerFactory" verb="*" path="*.asmx" preCondition="integratedMode" type="System.Web.Script.Services.ScriptHandlerFactory, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/> <add name="ScriptHandlerFactoryAppServices" verb="*" path="*_AppService.axd" preCondition="integratedMode" type="System.Web.Script.Services.ScriptHandlerFactory, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/> <add name="ScriptResource" preCondition="integratedMode" verb="GET,HEAD" path="ScriptResource.axd" type="System.Web.Handlers.ScriptResourceHandler, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/> </handlers> </system.webServer></configuration>
If I go into the Design view of my .aspx page I can see the WebDialogWindow and apply settings but when I added the button and went to the code behind it doesnt recognize the following code:Me.WebDialogWindow1.WindowState = Infragistics.Web.UI.DialogWindowState.NormalHere is what I currently have in my code behind:Partial Class _Default Inherits System.Web.UI.Page Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load End Sub Protected Sub btnShow_Click(ByVal sender As Object, _ ByVal e As System.EventArgs) Handles btnShow.Click Select Case Me.WebDialogWindow1.WindowState Case Infragistics.Web.UI.LayoutControls.DialogWindowState.Hidden Me.WebDialogWindow1.WindowState = _ Infragistics.Web.UI.DialogWindowState.Normal End Select End SubEnd Class
Is there something I am missing?I have been through a great deal of pain trying to upgrade to NetAdvantage for .Net 2008 Vol. 2 CLR 3.5 and so far this is just me trying to work things out locally. Hopefully I wont have to go through the same headaches and wasted hours when I want to push something out to production.
Indeed, upgrading projects from ASP.NET 1.x / 2.0 to 3.5 can sometimes be painful. I believe that in this particular case the projects itself is being run as a ASP.NET 2.x project. If you right-click on the project, choose Properties you will see a dropdown with target ASP.NET platform. Changing it from 2.0 to 3.5 will hopefully solve the problem.
You can also Google the error message, since this appears to be a common problem for many developers (not only that ones using Infragistics controls) and there are various suggestions to address this problem
http://www.google.com/search?q=his+Project+references+a+prior+version+of+System.Web.Extensions+version+1.0.61025.0&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
Thank you very much for the reply. We actually just upgraded to Visual Studio 2008 (which already has the Properties set to 3.5). Everything is working wonderfully.
