We upgrade to Infragistics45.Web.v15.1, Version=15.1.20151.1018 today and are getting lot of errors. I am looking for the release notes to see what was changed in this release. I have seen these before but cannot located them now. Where are they?
Hello Autumn,
Could you please share a sample replicating your issue?
So we can debug it an find out what is causing the errors?
Thanks in advance!
Looking forward for hearing from you.
My coworker John has already opened a ticket with a project example that shows the error. I am just trying to find the release notes of what was changed in the releases? Is this available?
I have created case for you with id CAS-159348-J2L9B8. You could reach your case following the link bellow:
https://www.infragistics.com/my-account/support-activity I will update you via the mentioned case, so if you have any further questions or comments please update your case.
Autumn,
When service releases and volume releases are released release notes are published in the blogs:
http://www.infragistics.com/community/blogs/tags/Release+Notes/default.aspx
For the 15.1 ASP.NET release there were no release notes published though the same bugs that were addressed in the earlier volume would also have been addressed in 15.1. You could review all of the past service release notes for ASP.NET and see what is relevant between the two volumes.
Thanks. I guessed that after I found the release notes in our downloaded packages for all releases except this one. FYI - we were told our problem was introduced because WebTab.InstantiateTemplates() was removed from the OnInt in the WebTab. We have back out the IG release because this is going to be too much work to handle in our products release.
