I currently have a grid that sets the ' configGrid.AutoresizingMask = UIViewAutoresizing.FlexibleWidth; ' property to make sure that the grid fills the whoel width of its parent view.
When I populate hte grid with 100 rows and 4 columns this works as expected; it fills the width of the view and I can scroll vertically through the list.
However, if I populate the grid with 100 rows and 30 columns, I cannot get it to scroll horizontally through the additional columns.
What property/method am I missing?
Cheers,
Paul
Ok, using the code below, the grid all works except for the horizontal scrolling. All the columns have been effectively' best fitted' to the grid. I know I must be causing that and it something obvious, but I just cannot see it! help!
public override void ViewDidLoad () { base.ViewDidLoad (); // Create a new gridview IGGridView configGrid = new IGGridView( new RectangleF(0,0,(this.View.Bounds.Width),this.View.Bounds.Height),IGGridViewStyle.IGGridViewStyleDefault); // Enable flexible width so that the grid feels its parents view configGrid.AutoresizingMask = UIViewAutoresizing.FlexibleDimensions; // Enable 2way Scrolling //Grid.common.gridconfig.enableScrolling (true, true, configGrid); // Configure grid theme configGrid = configuretheme.themegrid(configGrid); // Add gridview to the current view this.View.Add(configGrid); // Sort out custom column headers if (common.customcolumnheaders.Count != 0) { configdsh = common.configureheadertitles (configdsh, common.customcolumnheaders); } // Add data to the grid configdsh.Data = common.griddatasource.ToArray(); configGrid.DataSource = configdsh; // Attempting to override column width without the use of a delegate configGrid.ColumnWidth = IGColumnWidth.CreateNumericColumnWidth (200f, 200f); // Set the filter to always be displayed and configure the default settings configGrid.FilterAction = IGGridViewFilterAction.IGGridViewFilterActionImmediate; configdsh.FilterType = IGGridViewFilterConditionType.IGGridViewFilterConditionTypeStringContains; string defaultValue = common.customcolumnheaders.Values.ElementAt(0); configdsh.FilteringKey = defaultValue; // The following code is used to enable the filtering popup from the navbar button // Configure the popover control for the filter button. gridfilterpopup content = new gridfilterpopup(); content.callinggriddsh = configdsh; content.callinggridcontroller = configGrid; content.callingcustomcolumnheaders = common.customcolumnheaders; filterpopover = new UIPopoverController (content); filterpopover.PopoverContentSize = new SizeF(320,320); // Configure the navigation controller for this view // Configure a filter button UIBarButtonItem filterbtn = new UIBarButtonItem (UIBarButtonSystemItem.Action); filterbtn.Clicked += delegate { // If the popover is already showing from the bar button item, dismiss it. Otherwise, present it. if (!filterpopover.PopoverVisible) filterpopover.PresentFromBarButtonItem (filterbtn, UIPopoverArrowDirection.Any, true); else filterpopover.Dismiss (true); }; this.NavigationItem.SetRightBarButtonItem (filterbtn, true); configGrid.ReloadInputViews (); }
Hey Paul,
I haven't had a chance to test out your code yet.
However, after a quick review, it looks like the problem you're running into, is that you're setting the ColumnWidth after you set the dataSource. So you have 2 options, set the ColumnWidth before you set the dataSource on the grid, OR, call UpdateData() on the grid after you set the ColumnWidth(This tells the grid to redraw).
Let me know if this helps,
-SteveZ
Thank Steve, spot on. I got there just before you posted :)
