45
Why is IGGridView.Theme returning null after context switch?
After updating our app to use Xamarin's Unified API and the recent SR release, I started getting object ref crashes with grid.Theme == null where previously it had been populated.  I tracked it down to the code below and was wondering if this is a defect or if you could explain the behavior.  I've got a workaround for the problem (setting the theme again inside the task) but I don't understand why the property is getting nulled to begin with.
        private IGGridView grid;
        private List<Section> CreateSections(CoreGraphics.CGRect bounds, UIView topView)
            mainView = new UIView
                Frame = new CoreGraphics.CGRect(0, 0, bounds.Width, bounds.Height),
                AutoresizingMask = UIViewAutoresizing.None,
                BackgroundColor = UIColor.Clear
            grid = CreateGridView(gridFrame);
            grid.Theme = new PatientListGridTheme();  // custom Theme that inherits from IGGridViewThemeDefinition
            LoadGridData();
            mainView.Add(grid);
            return new List<Section> { main };
        private void LoadGridData()  // Invoked from UI thread
            Console.WriteLine(string.Format("Theme : {0}", grid.Theme == null ? "NULL" : grid.Theme.GetType().ToString()));
            //prints Theme : PatientListGridTheme
            Task.Run(async () =>
                        await Task.Run(() =>
                            //prints Theme : NULL !!!!!!!!
                            InvokeOnMainThread(() =>
                        InvokeOnMainThread(() => HideLoadingView());
