Is there a way to extend the size of visible allday view? At the moment it seems it is 3 rows and 2 columns and anything more than that has to be scrolled with in that view.
Thank you
Mark
or perhaps there is a way to disable AllDayEventAreaScrolling and make it display all allday appointments?
Hi Mark,
Correct, the limit is currently 2 Columns, 3 Rows, then scrolling.
I did this to mimic what Apple's calendar does, or at least did at the time of us writing it. That's not to say we couldn't offer additional options.
If you could provide some more details in what you're trying to achieve, I'd be happy to add some additional functionality.
-SteveZ
Hi Steve,
i am thinking about using Calendar control to convert our existing application to mobile xamarin version. In our existing application we have a scheduling feature where it i very important that user sees all "ALLDAY" events. In current 3 lines view it is easy not to notice that there are more appointments then visible 3.
i guess I need more an advise before I start the project - should I use calendar control and keep submitting enhancement features, create my own day view, build on top of an existing day view (for example an overlay with current time)? What is a turn around for infragistics to keep adding new features?
Hey Mark,
It generally comes down to the complexity. If the requests are simple enough, and important to your project, we can usually get them to you in a SR, or even a private SR.
If they're more complex, it would generally be a request for the next version, which, in this case 15.2, which would be coming out in the fall.
Something like the AllDay would be trivial and would fall into the former category, so if you really need it we could get it into an SR. We would still want you to log the idea into our UserVoice page, so we can track it though.
http://ideas.infragistics.com/forums/211525-nuclios
Steve,
I did submit the request and would like to see this feature implemented.
It is important for us that the user sees all lines and will not miss anything that was scheduled w/o specific time
