We have been using Infragistic.Excel (Version 14.1.20141.2019) for exporting data to excel (.xls). Now we need to export data to .Xlsx format.
We updated the code accordingly but the we are facing following error message:
Data does get populated if we hit Yes button, but how can we avoid this alert message?
Following is the simplified code used:
(WorkbookFormat.Excel2007);
It looks like you tried to post some images, but they did not come through. Please reply and attach the images to your post.
Error Screen Shot:
Code Snippet:
I'm not aware of any issues that would cause a problem like this.
It's possible that this was a bug in 14.1 and has since been fixed, so it might be a good idea to update to the latest service release or even a newer version of the controls.
How to get the latest service release - Windows Forms - Service Releases
If that does not help, then we would need to be able to reproduce the issue in order to investigate. Can you reproduce this in a small sample project and post it here so we can check it out?
