Two UltraTextEditor controls. One single line and one multi line. Both "always in edit mode"
The text in both aligns
Now if I change the font of the text box to Segoe UI it looks ok in the designer but when I run it the text is now significantly indented in the multi line box
This is a problem in 12.2 and it seems 16.2
Project attached - just run it to see
Hello Gwyn,
Out UltraTextEditor inherits most of its functionality from .NET TextBox. In this case, this is a behavior inherited from TextBox (you can try the experiment with TextBoxes instead of UltraTextEditors and see the same result).
Please let me know if I can further assist you.
