Good Day!
I have a form that contains both an UltraDayView and an UltraMonthViewSingle control. Both of these controls are bound to the same UltraCalendarInfo.
To the UltraCalendarInfo instance I’m creating and adding Appointments.
I can see the same appointments on both controls(UltraDayView and UltraMonthViewSingle) just fine. These 2 controls are each on a tab page.
In the tab page’s SelectedTabChanged event I’m setting the .Select() method on the appropriate control (so they have appropriate focus).
I’m handling the UltraCalendarInfo’s BeforeDisplayAppointmentDialog event so I can cancel the out-of-box Appointment dialog from loading. My intention is to…based on the .IsExistingAppointment property in the event…to execute custom functionality instead.
This is working fine on the UltraDayView. If I double-click on an appointment the event states that IsExistingAppointment is True and e.Appointment contains the appropriate appointment.
However it is not working properly when I double-click on the same appointment in the UltraMonthViewSingle.
Two odd things I see:
1) the BeforeDisplayAppointmentDialog event doesn’t fire until I have clicked somewhere other than on an existing appointment. Once I do then and ony then does the BeforeDisplayAppointmentDialog event fire.
2) In the BeforeDisplayAppointmentDialog event when I double-click on an appointment in UltraMonthViewSingle the e.IsExistingAppointment is False and e.Appointment is a “new” Appointment…not the Appointment I double-clicked on.
Any help/assistance would be much appreciated!
