Hi, can you please help me..
I try to update the size point of text, because, like we see, there is no enough space.
the objective is to not have "TExtBodytoseeeaga..." BUT "TExtBodytoseeeagainyes"
I have try this
Dim TileWideSIT As TileWideSmallImageAndText02
Dim LiveTil As LiveTile
LiveTil.Appearance.Normal.FontData.SizeInPoints = 3
TileWideSIT.Appearance.Normal.FontData.SizeInPoints = 3
BUt the SizeInPoints have strictly no effect on the font size...
Do you Know how can I Do this .??....minimise the font size in order to be able to see all text...
Thanks in advance for your Help.
Regards.
Hello Fred,
To change the FontSize you can set the SizeInPoints property off the Tile’s Apperance->FontData object like you are doing here. However, if you want to specify how text should be rendered when there is not enough room to display the entire string then I recommend using the TextTrimming property of the Tile.
If you are not seeing any change in FontSize after setting the SizeInPoints property then we need a sample to further look into this issue.
Please let me know if you have any questions. Sincerely,Sahaja KokkalagaddaAssociate Software Developer
it's not work...
Can you test this example please and give me your response;????????
private void Form1_Load(object sender, EventArgs e)
for (int m = 0; m < this.ultraLiveTileView1.Groups.Count; m++)
for (int pp = 0; pp < this.ultraLiveTileView1.Groups[m].Tiles.Count; pp++)
// this SizeInPoints do nothing
this.ultraLiveTileView1.Groups[0].Tiles[pp].Appearance.Normal.FontData.SizeInPoints = 15;
this.ultraLiveTileView1.Groups[0].Tiles[pp].Appearance.Normal.TextTrimming= TextTrimming.EllipsisCharacter;
Changing the text size on a LiveTile is different than changing the text size of a static tile. It is a bit more complex. A LiveTile may contain more than one text element in its content so the TextSize of that specific text element has to modified in order to change the TextSize of that Tile. You can set the TextSize property off the LiveTileContentTextElement to achieve this.
Please let me know if I may be of further assistance.
Hi Sahaja,
Thanks for your answer...
We have created a Custo tile... witch allow us to create small textelement in the tile....for the moment it seems to be enough....
If we need to create other size I will post a new post....
Thanks for your action.
Fred.G
