I would like to know which method/object I can call/instantiate to launch the grid designer at runtime. Also, I need to be able to launch the UltraCombo designer!
Thanks!
James
Hi again,
Perhaps I should expand the problem a little to assist with someone answering the question...
I have created a user control that has a couple of controls within, one of them a grid. When I drop the user control onto a form I would like to be able to activate the designer for the grid so it can be setup (as I would like to do with a combo, if I was using one within the control).
I thought that a method around this would be runtime activation, but actually even design-time activation of the designer would be nice, if I could do it to the user control. Would it work if I exposed the inner grid, and added some smart tag which would allow a similar activation to "Ultragrid Designer" on the pop-up menu?
Thanks in advance!
Hi James,
I don't beleive this can be done.
Hi Mike,
Is there any way you can get a definitive answer - it must be quite a common requirement! I don't need it to be runtime activated, provided I can get it to activate in design-mode on the user-control. And I don't want to my usercontrol to inherit from your grid!
Thanks for your help!
I'm 95% sure this is not possible. If you want to double-check, I recommend that you Submit an incident to Infragistics Developer Support
The designer is not accessible via the Start button, however you can access it by clicking on the small triangle at the top right of the grid and a dropdown will appear where you can select Designer Dialog... or you can right-click on the grid and select UltraGrid Designer
Erwin
