155
DockableControlPane Pin is not visible
First Issue:
When I open application from Citrix server then DockableControlPane Pin is not visible.When I hover the mouse then the DockableControlPane Pin/UnPinned functionality is working But Pin Image is not visible on UI.
But,When i open same application on local machine then this issue not occurs.
Second Issue:
When I open application from Citrix server then Infragistics.Win.UltraWinEditors.UltraCheckEditor checkboxes is cutting.
Both issues only occur on Citrix server only.
Can you please suggest?
  • 28945
    It might be something in the application that is causing these controls to paint slowly. Since Citrix has to basically transmit a screen shot to the client machine every time the window paints on the server, an excessive number of paint messages can slow things down. Our controls are not tested under a Citrix environment. Is there any way to refresh the Citrix’s screen explicitly? You can try refreshing your controls; all Windows Forms controls have refresh method that forces the controls to re-draw itself.
