First Issue:
When I open application from Citrix server then DockableControlPane Pin is not visible.When I hover the mouse then the DockableControlPane Pin/UnPinned functionality is working But Pin Image is not visible on UI.
But,When i open same application on local machine then this issue not occurs.
Second Issue:
When I open application from Citrix server then Infragistics.Win.UltraWinEditors.UltraCheckEditor checkboxes is cutting.
Both issues only occur on Citrix server only.
Can you please suggest?
