if cell value is negative then set in bracket . how?
eg. If cell value is -45 then change the cell value to "(45)" like that.
I am doing like that.
UltragridRow.Cells[i].Value="(45)"
but my cell datatype is double thats why above statement gives error .
error is - unable to convert from system.double to system.string.
Can we change cell data type instead of changing datasourse column data type.
Hello Vijay,
To achieve this behavior you will want to apply a format to the field:
docs.microsoft.com/.../custom-numeric-format-strings
<ig:Field Name="Department" Format="##;(##)" />
