I use Infragistics version 19.1.20191.82.
How to set one column editable, of UltraCombo?
For example, I want to be able to select one line and also change "Age" value
I had been try several ways but I did not found.
this is not work :
Do you have a solution to suggest me? (other control than UltraCombo for example)
Thanks for your advice, I join here my example project.
InfragisticsTestControls.rar
Hello and thank you for contacting Infragistics. The UltraCombo itself cannot be editable. It exposes some basic functionality like checking checkboxes. However our editors eg. UltraTextEditor exposes a Button's Left/Right collection. There you can mimic a custom dropdown and display out UltraGrid. Our UltraCombo is essentially a UltraGrid.
eg.
https://www.infragistics.com/community/forums/f/ultimate-ui-for-windows-forms/18024/ultracomboeditor---can-i-use-a-custom-control-for-the-dropdown
