Can someone explain to me how to make an unordered, bulleted list or an ordered numbered list inside of the UltraFormattedTextEditor? I have found the sample code that comes with the v6.3 for the "Ribbon With FormattedTextEditor CS" project, but it doesn't have any examples of how to make a button that does this. Also, there is little to no documentation on what are the various string inputs that can be used on the ApplyStyle method. I wasn't sure if that was how I needed to start/stop a list in my text box. Any help would be appreciated.
The formatting tags are documented here.
Thank you for your quick response, Mike. I have submitted a request to the link you provided.
Regarding my other question, is there any documentation on the FormattedTextEditInfo.ApplyStyle method and the various string inputs that can be supplied to it? It's not very clear to me what the input "styleString" formats should be, and I can't seem to find anything in the Knowledge Base or forums on this method.
I think the link to the documentation I gave you above lists all of the tags that the control supports, so those would be the same tags that ApplyStyle can take.
The "documented here" link seems to be giving a server error.
Hello AB,
You are correct. The link is no longer available since it is still pointing to the 2008 vol2 documentation which is no longer available. Please visit the link below from our current documentation:
http://help.infragistics.com/NetAdvantage/WinForms/current/html/?page=WinFormattedLinkLabel_Formatting_Text_and_Hyperlinks.html
If you have any other questions please do not hesitate to contact us.
