Del
I was not able to reproduce the flicker issue you described here; you might want to log an incident with Developer Support so you can provide the details ncessary to reproduce that behavior.
Hi Brian,
I am running the following:
The problem is that at this point the tick has already been placed in the checkbox before the this event is alling the cancel.
Regards
I must have misinterpreted your use of the word "flicker". If you are using the Office2007 glyph style for the checkboxes, the issue you describe might be a bug that was recently reported. You should log an incident with Developer Support so that you are notified when a fix becomes available.
