1284
AfterColPosChanged event fired through code
Hi
    I am working on a .NET 2.0 application using Ultrawingrid.
AfterColPosChanged event is fired when i resize the column manually using mouse or when i
change the width of the column through code.
I want to prevent some part of code from executing if it is fired through code.
How to  check whether AfterColPosChanged event is fired manually or through code?
Ashok
  • 469350
    Hi Ashok,
    Typically, what you would do is set a flag when your code is changing something, then check that flag within the event handler. If the flag is not set, you know the change was made by the user.
