1284
Save Ultrawingrid properties
Hi
Is there any inbuilt functionality to save Ultrawingrid properties such as Column width,Visible position, Sort order of the columns?
I want save these  properties and set these properties to grid when i load the data again.
I want to save these user specific settings for every user and load data according to his settings.
Ashok
  • 469350
    Hi Ashok,
    The easiest thing to do is use the grid.DisplayLayout.SaveXXX method. You can save the layout to a binary or XML file and then use the Load method to load it back in when the project loads.
