1284
DisplayLayout.SaveAsXML - UltraGridColumn Node Missing
Hi
  I am using Ultrawingrid.Displaylayout.SavaAsXML method to save the layout of the Grid.
there is a node called "UltraGridCilumn" in the XML file. This node is missing is the XML for some grids.
when i Call DisplayLayout.LoadFromXML method column changes like width,Position are not retained.
It is working fine for other grids which has this node information in the XML.
 <a1:UltraGridColumn id="ref-38" xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinGrid/Infragistics2.Win.UltraWinGrid.v8.1">
<CharacterCasing>1</CharacterCasing>
<CellAppearanceHolder href="#ref-60" />
<Header href="#ref-61" />
<Key id="ref-62">DistId</Key>
<Width>561</Width>
<IsBound>true</IsBound>
</a1:UltraGridColumn>
Ashok
