I have an object collection of objects with a single member (say Name) as the only field in it. I bind it to the ultra grid and the results are displayed as a sing column multiple rows with each object string value in each row. That is the default behavior. I want to swap the alignment and display the values as a single row.
The Current Display is
Allen
Stevens
Phil
I want it to display it as
Allen Stevens Phil
Just swap the way rows and columns are displayed. Is there a way to achieve this and if so any small code sample would be a lot helpful.
The grid displays the data yougive it based on the structure of the data source. So you would need to create a data source where you have a single row (object in a list) with multiple properties - one for each string you want displayed in the row.
