In the past, I was able to download demos and it's source code. With the new website layout, I can't find it anymore. Can someone please send me the link for Winform Demo ?
xczhao,
If you have installed the latest product, NetAdvantage for Win Client 2009 Vol 1, the samples and their source code were included in the product installer. You can find the source code located at the following location on your machine: C:\Documents and Settings\All Users\Documents\Infragistics\NetAdvantage for .NET 2009.1\Windows Forms\Samples
Hope this helps,
~Kim~
I just accepted a contract that includes use of Infragistics controls. I downloaded the trial version so that I could start learning about them. On the path noted above: C:\Documents and Settings\All Users\Documents\Infragistics\NetAdvantage for .NET 2009.1\Windows Forms, there is only one folder: AppStylist for Windows Forms. Where can I find full samples to explore, or are they crippled because of the trial version? Thanks in advance for any ideas and/or suggestions!
j2associates,
It looks like my previous post was incorrect. The NetAdvantage for Windows Forms samples are actually a different installer than the product itself. If you have downloaded the NetAdvantageSelect20091.zip or NetAdvantageWinClient20091.zip files, then the "NetAdvantage_WinForms_Samples_20091.exe" file, which is the samples installer, was part of it. You will need to run this installer in order to install the samples, and then they can be found at the aforementioned location on your machine.
My apologies for the misinformation,
I know this is an old thread - but I came across it wondering why it is so difficult to find demos of the controls. I've had a license to the ultimate bundle for a long time and all I'm trying to do is look at the functionality of one of the controls to see if I want to use it. I've searched the website, I've looked in my infragistics program folder. I know I installed the samples when I installed the controls, but can't find them. Are there simply links to launch demos somewhere on the website?
Hello elondon,
If you have already installed the samples to your machine and need to access the Windows Forms Samples you could do the following:
Assuming that you are using Windows 7 Click on the start menu button / All Programs/ Infragistics / NetAdvantage Version / Desired Product (Windows Forms) / Samples /Samples Localor they are located under the similar location like the one below:
C:\Users\your user name\Documents\Infragistics\NetAdvantage 2011.1\ Desired Product (Windows Forms)\SamplesIf you have any other questions please do not hesitate to contact us.
