the ColumnChooserButton has a default tooltip of "Click here to show Field Chooser."
is there any way to override/change this?
see
http://help.infragistics.com/Help/NetAdvantage/NET/2008.2/CLR2.0/html%5CWinGrid_Resource_Strings.html
Thanks in advance.
Sunny
Hello Sunny,You can find all customization strings for WinGrid and ColumnChooserButton in the link you mention: http://help.infragistics.com/Help/NetAdvantage/NET/2008.3/CLR2.0/html/Win_Customizing_Assembly_Resource_Strings.htmlAnd you can use SetCustomizedString method of the ResourceCustomizer to set your own string using the sample code below:Infragistics.Shared.ResourceCustomizer rc;rc.SetCustomizedString("ColumnChooserButtonToolTip", "New ColumnChooserButtonToolTip_Text");You can also look at the online help how to use Resource Customizer:http://help.infragistics.com/Help/NetAdvantage/NET/2008.2/CLR2.0/html/Win_Customizing_Assembly_Resource_Strings.htmlI hope this information was helpful.Sincerely,DimiDeveloper Support EngineerInfragistics, Inc.
