Hi
I have a grid which uses column filters, but when I export to Excel using UltraGridExcelExporter, even the filtered out rows are sent to the spreadsheet.
What am I doing wrong?
Graham
What I said previously was not exactly true - perhaps I should explain a bit more. I have a form that allows users to enter Excel formlae to perform calculations on the grid. On the form I have a label which displays the number of rows in the grid.
It turns out that when I apply the formulae, it is indeed only being applied to the filtered in rows, the problem I have is calculating the number of these rows to display in the label. I was using m_oGrid.Rows.Count which is clearly not correct.
So how do I find out how many rows are displayed?
Thanks again
I got there in the end: oGrid.Rows.FilteredInRowCount
Sorry for the unnecessary post!
