Hi, I was building an UltraWinTree and bind it to objects. My original dataset in database for Test1 has 3 levels, after I insert a new record of Test1 on any of the existing level, it’s shown correctly, but if I insert a new record of Test1 into the database on a new level, i.e. adding a child to a level3 Test1 node, when I rebuild the tree, it doesn’t show this new node on the new level (level4). My original Test2 dataset in database has 4 levels. The tree does show all nodes on all the levels properly. Again, when I tried to insert a record of Test2 into the database on level5, it’s not shown either. It looks like the tree is not shown correctly when I want to add a node on a new level. I attached some code that I used to build the tree. Hope it will help explain my issue. Thanks.
Thanks.
public void BuildTree(string root, UltraTree treeView)
if (root == "TestRoot1")
List<Test1> rootList = new List<Test1>();
foreach (Test1 r in LoadData_Test1())
if (r.Name == root)
rootList.Add(r);
treeView.SetDataBinding(rootList, null);
else if (root == "TestRoot2")
List<Test2> rootList = new List<Test2>();
foreach (Test2 r in LoadData_Test2())
Hi Michelle,
It's hard to tell just from a code snippet. But my guess is that the tree's ColmunSets don't have any information for level 4, since this band did not exist when the application started. A child band is actually just a special type of column. So if you add a band to your data source, the ColmunSet of the parent band needs to contain a column that represents that band and has it's IsChaptered property set to true.
