I'm creating a custom control inherited from the UltraCombo for a standard lookuplist of foreign relationships that I can use in my entire program. However, I'm having a databinding issue, which maybe a simple fix because I'm new at using databinding in VB. The list in this Combo will always be filled with an Id (perhaps CustomerId) and some string value (perhaps CustomerName). For this explaination I'll use the a basic relationship of Orders and Customers in which I have an Order form with a bindingsource call OrdersBindingSource and a combo of customers. The combo list will be filled with CustomerId and CustomerName. The CustomerName value will be the DisplayMember AND ValueMember of the combo (I know this is unusual). I added a property to this new combo class called "ID" and set my databindings for the combo to: ID = OrdersBindingSource.CustomerId and value = OrdersBindingSource.CustomerName. Everything is good at this point. When I run my program the combo displays the customer name (even if the customer name is not in the combo list) and popluates the combo.Id property. However, when a customer is selected from the combo I need it to update the OrdersBindingSource.CustomerId as well as the OrdersBindingSource.CustomerName, but this is not happening. It's only changing the OrdersBindingSource.CustomerName. How do I get the OrdersBindingSource.CustomerId to update when the Combo.Id value is changed?
Here is my basic combo property settings:Display Member: CustomerNameValue Member: CustomerName
Databindings for comboID: OrdersBindingSource.CustomerIdValue: OrdersBindingSource.CustomerName
New Combo Class CodePublic Class UltraFlexCombo Inherits Infragistics.Win.UltraWinGrid.UltraCombo
Private _Id As Long
Private Sub UltraFlexCombo_ValueChanged(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.ValueChanged Me.Id = Me.ActiveRow.Cells("Id").Value End Sub
<Bindable(True), DefaultValue(0)> _ Public Property Id() As Long Get Return _Id End Get Set(ByVal value As Long) If _Id <> value Then _Id = value End If End Set End PropertyEnd Class
I think I need to raise the OnPropertychanged Event or NotifyPropChange event in the Set method of the Id property, but I'm not sure how to implement this.
I think I've got it.
I had to Implement INotifyPropertyChanged and then Shadows the PropertyChanged Event declaration and then I ended up updating my value in the Validating event.
Public Class UltraFlexComboInherits Infragistics.Win.UltraWinGrid.UltraComboImplements INotifyPropertyChanged
Public Shadows Event PropertyChanged As PropertyChangedEventHandler Implements INotifyPropertyChanged.PropertyChanged
Private Sub NotifyPropertyChanged(ByVal info As String) RaiseEvent PropertyChanged(Me, New PropertyChangedEventArgs(info))End Sub
Private Sub UltraFlexCombo_Validating(ByVal sender As Object, ByVal e As System.ComponentModel.CancelEventArgs) Handles Me.Validating Me.Id = Me.ActiveRow.Cells("Id").ValueEnd Sub
<Bindable(True), DefaultValue(0)> _Public Property Id() As Long Get Return _Id End Get Set(ByVal value As Long) If _Id <> value Then _Id = value NotifyPropertyChanged("Id") End If End SetEnd PropertyEnd Class I've only done limited testing, but it seems to work so far.
