Is it possible to display a drop down list on a column header, so that a user can select an item from this list and then all records in the grid could be filtered based on this selection.
Yes, just set:
grid.DisplayLayout.Override.AllowRowFiltering = true;
Thanks very much.
But can you just set filtering on certain columns and customize what appears in the drop down list?
jcusack01 said:But can you just set filtering on certain columns
Yes, you can set AllowRowFiltering on the column instead of (or in addition to) on the Override.
jcusack01 said:customize what appears in the drop down list?
Yes, you can do this in the BeforeRowFilterDropDown or BeforeRowFilterDropDownPopulate events.
