I got the following error while i was trying to load Excel file stream. I am using Infragistics35.WebUI.Excel.v9.2. Version=9.2.20092.2056.
I can open the file from MS Excel.
Index was out of range. It must be non-negative and less than the size of the collection.
Parameter name: index .
위치: System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource) 위치: System.ThrowHelper.ThrowArgumentOutOfRangeException() 위치: System.Collections.Generic.List`1.get_Item(Int32 index) 위치: Infragistics.Excel.Serialization.BiffRecordStream.CacheNextBlock(Byte[]& buffer, Int32& bufferPosition) 위치: Infragistics.Excel.Serialization.BiffRecordStream.ReadFormattedStringBlock(UInt32 stringCount, List`1 formattedStrings) 위치: Infragistics.Excel.Serialization.BIFF8.BiffRecords.SSTRecord.Load(BIFF8WorkbookSerializationManager manager) 위치: Infragistics.Excel.Serialization.BIFF8.BIFF8WorkbookSerializationManager.LoadCurrentRecord() 위치: Infragistics.Excel.Serialization.BIFF8.BIFF8WorkbookSerializationManager.LoadWorkbookContents() 위치: Infragistics.Excel.Serialization.WorkbookSerializationManager.Load() 위치: Infragistics.Excel.Workbook.LoadBIFF8File(Workbook workbook, Stream stream, String parameterName) 위치: Infragistics.Excel.Workbook.LoadHelper(Stream stream, WorkbookFormat format, String parameterName, IPackageFactory packageFactory, Boolean verifyExcel2007Xml) 위치: Infragistics.Excel.Workbook.Load(String fileName, IPackageFactory packageFactory, Boolean verifyExcel2007Xml) 위치: Infragistics.Excel.Workbook.Load(String fileName) 위치: Financial_ComunicationCorpEntry.ImportFromExcel(Object sender, EventArgs e) 파일 e:\KAIT\accountsolution\Account\Financial\ComunicationCorpEntry.aspx.cs:줄 996
Hi , This seems known error, but I may be wrong since I don’t have more details about the file you are trying to load. So I can suggest you to get the latest service release and test you application with it. Also you are reporting this for a web application, where this Windows Forms forum.I hope this helps.Sincerely,DimiDeveloper Support EngineerInfragistics, Inc.
