Hi.
Is there a way to define a counterclockwise scale in a radial gauge?
I tried using an EndValue less than the StartValue, but it didn't work.
Thanks.
Raul
Hello Raul,
To achieve your goal you may to set on Scale Layout End to be less than Start property, then the scale will turn to counterclockwise.
Let me know if you have any future question.
I am just checking about the progress of this issue. Did you achieve your goal accordingly the information that I provided to you?
