Hi.
I put two concentric scales on a radial gauge.
There are two needle markers, one shorter (for the inner scale), one longer (for the outer scale).
If I add the outermost scale first, the longer needle is displayed under (in z-order) the innermost gauge.
If I add the innermost scale first, the longer needle appears on top of the shorter needle, hiding it when they overlap.
I would think that the needles should always appear on top of any scale, but this does not seem to be the case.
Is there a way to make it work as expected?
Thanks.
Raul
Hello Raul,
I am just checking about the progress of this issue. Did you solve your issue accordingly the information that I provided to you?
Let me know if you need any further assistance.
