Hi.
Is there a way to make WinCalcManager perform calculations with aggregation by band (UltraWinGrid is envolved).
For instance. I'd like column Band[0].[Sum] ([Sum] is a column in Band[0]) equals Sum(Band[1].[Item]), where [Item] is a column in Band[1].
Thanks in advance.
Yes. The formula for the Sum column in Band 0 would look something like this:
"sum( [../band 1/item] )"
