365
NullReferenceException when resizing the rows
I've a bug in some old code. The Exception occurs infrequent, when calling PerformAutoSize of a UltraGridRow. Maybe this is a multi threading issue: The method calling PerformAutoSize is triggered by the ListChanged event of the DataView.
System.NullReferenceException: Object reference not set to an instance of an object.
  at Infragistics.Win.UltraWinGrid.UltraGridColumn.GetCachedCellAppearance(Boolean selected, AppearanceData& appData, ResolveAppearanceContext& context)
  at Infragistics.Win.UltraWinGrid.UltraGridRow.ResolveCellAppearance(UltraGridColumn column, AppearanceData& appData, AppearancePropFlags& requestedProps, Boolean cellAppearanceOnly, Boolean forceSelected, ForceActive forceActive, Boolean isMergedCell, Boolean hotTrackingCell, Boolean hotTrackingRow, Boolean isProxyResolution)
  at Infragistics.Win.UltraWinGrid.UltraGridLayout.ResolvedCachedCellAppearance(UltraGridRow row, UltraGridColumn column, AppearanceData& appData, AppearancePropFlags& flags, Boolean hotTrackingCell, Boolean hotTrackingRow)
  at Infragistics.Win.UltraWinGrid.GridEmbeddableEditorOwnerInfoBase.ResolveAppearance(Object ownerContext, AppearanceData& appearance, AppearancePropFlags& requestedProps, EmbeddableEditorArea area, Boolean hotTracking, String customArea, Boolean isProxyResolution)
  at Infragistics.Win.UltraWinGrid.GridEmbeddableEditorOwnerInfoBase.ResolveAppearance(Object ownerContext, AppearanceData& appearance, AppearancePropFlags& requestedProps, EmbeddableEditorArea area, Boolean hotTracking, String customArea)
  at Infragistics.Win.EditorWithText.InternalGetSize(EmbeddableEditorOwnerBase owner, Object ownerContext, Boolean valueOnly, Boolean full, Boolean includeBorders, Int32 maxTextWidth, Boolean allowMultiline, Boolean includeOwnerPadding, Boolean isTooltip)
  at Infragistics.Win.EditorWithText.GetSize(EditorSizeInfo& sizeInfo)
  at Infragistics.Win.EmbeddableEditorBase.GetSize(EmbeddableEditorOwnerBase owner, Object ownerContext, Boolean valueOnly, Boolean full, Boolean borders, Int32 maxTextWidth)
  at Infragistics.Win.UltraWinGrid.RowAutoSizeLayoutManagerHolder.RowAutoSizeCalculator.GetIdealCellSize(UltraGridColumn column)
  at Infragistics.Win.UltraWinGrid.RowAutoSizeLayoutManagerHolder.CellLayoutItem.get_PreferredSize()
  at Infragistics.Win.Layout.GridBagLayoutManager.GetItemSizeHelper(ILayoutItem item, Boolean minimum)
  at Infragistics.Win.Layout.GridBagLayoutManager.CalculateGridBagLayout()
  at Infragistics.Win.Layout.GridBagLayoutManager.GetGridBagLayoutCache()
  at Infragistics.Win.Layout.GridBagLayoutManager.get_ColumnWidths()
  at Infragistics.Win.UltraWinGrid.RowAutoSizeLayoutManagerHolder.VerifyCachedLayoutManager()
  at Infragistics.Win.UltraWinGrid.UltraGridRow.CalculateAutoHeight()
  at Infragistics.Win.UltraWinGrid.UltraGridRow.PerformAutoSize()
