Hi,I'm using an example I saw here in the forum to display images and text in a single cell: private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e) { UltraGridLayout layout = e.Layout; UltraGridBand band = layout.Bands[0]; UltraGridColumn column0 = band.Columns[0]; column0.Style = Infragistics.Win.UltraWinGrid.ColumnStyle.FormattedText; } private void Form1_Load(object sender, EventArgs e) { StringBuilder sb = new StringBuilder(); string imageString = GetImageTag(this.imageList1.Images[0]); sb.Append(imageString); sb.Append("Text1"); imageString = GetImageTag(this.imageList1.Images[1]); sb.Append(imageString); sb.Append("Text2"); imageString = GetImageTag(this.imageList1.Images[2]); sb.Append(imageString); sb.Append("Text3"); this.ultraDataSource1.Rows.Add(new object[] {sb.ToString()}); } private static string GetImageTag(Image image) { return string.Format("<img style=\"width:{0}px; height:{1}px;\" data=\"{2}\"/>", image.Width, image.Height, Infragistics.Win.FormattedLinkLabel.FormattedLinkEditor.EncodeImage(image)); }
The images are displayed fine and I can see the text...but I'm unable to select the text in the cell ( for copy/paste) how do enable that in this scenario?
Set the Style of the column to FormattedTextEditor instead of FormattedText.
