I have successfully changed the color but have not been able to get the gradient to work on the "ActiveDay" on the "UltraMonthViewSingle" control.
Is there a parent object that is overriding my code? What am I missing? I am executing my code on the Form_Load event. Please see below:
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
Dim ultraLook As New UltraCalendarLook
ultraLook.ActiveDayAppearance.BackColor = Color.BlueViolet
ultraLook.ActiveDayAppearance.BackColor2 = Color.BlueViolet
ultraLook.ActiveDayAppearance.BackGradientStyle = Infragistics.Win.GradientStyle.Elliptical
'' uMonth is the "UltraMonthViewSingle" control on the form....
uMonth.CalendarLook = ultraLook
End Sub
I found it.... "BackColor2" property is used for the gradient shading. All I had to do is delete the line that uses the "BackColor" property.
