Hallo,
I have some StateButtons visible in the toolbar, and if their ToolbarDisplayStyle is Button then they highlight nicely when the mouse goes over them (at least in the 'not pressed' state), and show tooltips.
However, if the ToolbarDisplayStyle is Glyph (which I want), then they neither highlight with the mouseover nor do they display tooltips :(
Any ideas how to get the same behaviour for glyphs? Thanks! (Infragistics Version is 7.3)
It would seem to be a bug that, even as Buttons, they only show tooltips when _not_ depressed...
The highlight is not supposed to show over the item with the mouse over. Only the glyph should highlight. This can be seen with the glyph style check boxes on the View tab in Word 2007. However, the tool tips should display. I would recommend submitting this to the support group: http://www.infragistics.com/gethelp.
The glyph does not highlight though, that is my problem... Where can I control highlighting behaviour for glyphs?
thanks, Joel
The glyph should hot track by default. If it is not, it could be a bug and I would recommend submitting the issue to the support group: http://www.infragistics.com/gethelp.
