220
Creating a context menu on Ultragrid in WinForms
  I am using VS2010 with Infragistics NetAdvantage 10.3 Win CLR2x to build a program.  I've got an ultragrid and I want to put a right click context menu in the grid.
I looked through about 20 posts on this subject, and non have helped in the least.  I've found 2 projects on this site that supposedly show an example -- neither of them compile.
At one point, I *think* I found something called an UltraContextMenu control in the NetAdvantage tool box.  I added it to my UltraGrid control (because, of course, a standard contextmenu strip can't be dropped onto Ultragrid) and tried to get it to work.  I couldn't, so I deleted it from the Ultragrid control.
From that point on, I've never been able to find that control in the NetAdvantage toolox again.  It has completely disappeared.  Now I'm beginning to think I mistakenly dropped some other control on the grid and that was why I couldn't get it to work.
Interestingly, if I click on the UltraGrid control in design view, I can find the ContextMenuStrip field (ditto if I click on the Start button for grid designer), but I can't edit it, or set it to anything.
Ultimately, what I'm trying to do is SO simple, that I'm wondering if I've missed something very basic.  I just want to select some rows in the grid (which I can do), right click and allow the user to select Copy from the context menu.  At the moment, if they just do a ctrl-c, they copy all the selected rows to the clip board.
I've got this bit of code here:
 myUltraGrid.ContextMenuStrip  = new ContextMenuStrip();
 myUltraGrid.ContextMenuStrip.Items.Add("Copy");
And that actually creates the menu with the correct menu item in it (meaning only "Copy"), but I have no idea how to fire off an event, or catch an event that will allow me to take advantage of that.
Any help would be appreciated.
